[PROJ] failing tests
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Jan 22 05:28:23 PST 2025
Good catch!
Thank you.
On Wed, 22 Jan 2025, 14:24 Even Rouault, <even.rouault at spatialys.com> wrote:
> ok, looking closer there was a difference. conda-forge has updated from
> sqlite 3.47.2 to 3.48.0 and this is a upstream sqlite 3.48.0 regression
> I've reported at https://sqlite.org/forum/forumpost/36bbc86546
> Le 22/01/2025 à 00:24, Even Rouault via PROJ a écrit :
> But that happens in both OK and KO builds... A workaround could perhaps be
> to try force using SQLite3 from Conda ?
> just tried that in
> https://github.com/rouault/PROJ/commit/b2b3e3897094b312532310b6240a6685e077f4c5
> / https://github.com/rouault/PROJ/actions/runs/12897666174/job/35963244002
> : doesn't work unfortunately
> Comparing the logs show no obvious differences in runner version,
> compilers or third party libraries. So this is totally mysterious. I guess
> someone with access to a Mac will probably have to look at that
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250122/1f0e5863/attachment-0001.htm>
More information about the PROJ mailing list
