[PROJ] PROJ 9.6.1RC1 & PROJ-data 1.22RC1
    Kristian Evers
    kristianevers at gmail.com
    Mon Jun  2 06:38:07 PDT 2025
With +1’s from
Kristian
Javier
Even
Charles
Howard
Alan
I declare the motion passed.
Expect a release announcement within the next couple of hours.
/Kristian
> On 2 Jun 2025, at 07.21, Kristian Evers via PROJ <proj at lists.osgeo.org> wrote:
> PSC members,
> I forgot to start at vote for the promotion of the two RCs to final releases in good time. Seeing as there’s been no concerning
> reports on either of them I hope that everyone can accept a speedy process so we can get the releases out later
> today.
> I’ll start with my +1.
> /Kristian
>> On 25 May 2025, at 21.27, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> PROJ 9.6.1 and PROJ-data 1.22 are coming up for release shortly. In preparation for that here is a round
>> of release candidates for you to test.
>> The PROJ-data release includes
>> * Dutch grids for height conversions
>> * The Japanese JPGEO2024 geoid
>> * Latvian transformation grid for the LKS-2020 reference frame
>> * Transformation grid for EVRF2019 in Denmark
>> The release notes for the PROJ release can be found below.
>> Download the release candidates here:
>> https://download.osgeo.org/proj/proj-9.6.1RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.6.1RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.22RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.22RC1.zip
>> As always, please report back your findings when testing the release candidates. Either here
>> on the mailing list or as issue on GitHub.
>> /Kristian
>> # PROJ Release Notes
>> ## 9.6.1
>> ### Updates
>> * Update EPSG to 12.012 (#4498)
>> * Add an option to ship PDB files (#4505)
>> ### Bug Fixes
>> * Deal with South Orientated TMerc presented as regular TMerc but with Scale_Factor=-1 (#4427)
>> * Add missing 'limits' and 'algorithm' includes (#4444)
>> * CMake: avoid detection of C23 `#embed` on too old compilers (#4463)
>> * `createOperations()`: for NAD83(CSRS)[x] to NAD83(CSRS)[y], do not go through NAD83 (#4467)
>> * Add missing include for `uint32_t` on Windows with gcc 15.1 (#4478)
>> * `getGeoidModels`: use vertical_crs.datum_code to get vcrss that uses different units (#4480)
>> * `FileManager::open_resource_file()`: honour known URLs from grid_alternatives that don't point to cdn.proj.org (#4481)
>> * Database: update ESRI to ArcGIS Pro 3.5 (#4493)
>> * `createOperationsCompoundToGeog()`: avoid bringing non-sensical transformations (#4494)
>> * Bug correction in Wagner VI projection parameters (#4453)
>> * C++: Fix bare `isnan()` to `std::isnan()` (#4472)
>> * Database: fix duplicated entries with auxiliary database (#4482)
>> * Use `std::abs` instead of `abs` for NetBSD (#4486)
>> * Fix Windows build when both `EMBED_RESOURCE_FILES` and `USE_ONLY_EMBEDDED_RESOURCE_FILES` are set (#4508)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ
