[PROJ] PROJ 9.6.1 & PROJ-data 1.22
Kristian Evers
kristianevers at gmail.com
Mon Jun 2 07:11:02 PDT 2025
On behalf of the PROJ team I am happy to announce the release of
PROJ 9.6.1 and PROJ-data 1.22!
The PROJ release includes updates to the the database contents,
as well as a number of bug fixes. See the release notes below.
The PROJ-data release includes
* Dutch grids for height conversions
* The Japanese JPGEO2024 geoid
* Latvian transformation grid for the LKS-2020 reference frame
* Transformation grid for EVRF2019 in Denmark
Download the archives here:
http://download.osgeo.org/proj/proj-9.6.1.tar.gz
http://download.osgeo.org/proj/proj-9.6.1.zip
http://download.osgeo.org/proj/proj-data-1.22.tar.gz
http://download.osgeo.org/proj/proj-data-1.22.zip
/Kristian
# PROJ Release Notes
## 9.6.1
### Updates
* Update EPSG to 12.012 (#4498)
* Add an option to ship PDB files (#4505)
### Bug Fixes
* Deal with South Orientated TMerc presented as regular TMerc but with Scale_Factor=-1 (#4427)
* Add missing 'limits' and 'algorithm' includes (#4444)
* CMake: avoid detection of C23 `#embed` on too old compilers (#4463)
* `createOperations()`: for NAD83(CSRS)[x] to NAD83(CSRS)[y], do not go through NAD83 (#4467)
* Add missing include for `uint32_t` on Windows with gcc 15.1 (#4478)
* `getGeoidModels`: use vertical_crs.datum_code to get vcrss that uses different units (#4480)
* `FileManager::open_resource_file()`: honour known URLs from grid_alternatives that don't point to cdn.proj.org (#4481)
* Database: update ESRI to ArcGIS Pro 3.5 (#4493)
* `createOperationsCompoundToGeog()`: avoid bringing non-sensical transformations (#4494)
* Bug correction in Wagner VI projection parameters (#4453)
* C++: Fix bare `isnan()` to `std::isnan()` (#4472)
* Database: fix duplicated entries with auxiliary database (#4482)
* Use `std::abs` instead of `abs` for NetBSD (#4486)
* Fix Windows build when both `EMBED_RESOURCE_FILES` and `USE_ONLY_EMBEDDED_RESOURCE_FILES` are set (#4508)
More information about the PROJ
