[PROJ] PROJ 9.6.2 RC1 available
Even Rouault even.rouault at spatialys.com
Wed Jun 4 04:34:40 PDT 2025
Here's a release candidate for PROJ 9.6.2:
https://download.osgeo.org/proj/proj-9.6.2RC1.tar.gz
https://download.osgeo.org/proj/proj-9.6.2RC1.zip
Please test and report issues.
# PROJ Release Notes
## 9.6.2
### Updates
* Update EPSG to 12.013
### Bug Fixes
* Database: change ESRI deprecated records back to their deprecated
state (#4519)
* ProjectedCRS::identify(): more robust identification of old ESRI names
using _IntlFeet (#4518)
* Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name
(#4514)
* proj_trans_bounds(): sample points within the source grid to avoid
missing extent such as world-wide coverage from EPSG:4326 to ESRI:54099
(Spilhaus) (#4513)
* proj_trans_bounds(): avoid erroring out, in some cases, when PJ*
object is directly constructed from a PROJ pipeline (#4512)
Even
http://www.spatialys.com
More information about the PROJ mailing list
