[PROJ] PROJ 9.6.2 RC1 available
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Wed Jun  4 05:27:09 PDT 2025
Thanks Even
I run (with the phone, so it could be wrong) the crs-explorer generation
that detected the esri problem. It shows about 1000 crss "deprecated again"
That sounds good.
I cannot do more testing now just with the phone.
https://github.com/jjimenezshaw/PROJ-CRS-Explorer/actions/runs/15441798763/job/43461152152#step:9:1
Bonus: your algorithm to sample points in a world projection #4513 will be
sooner in qgis.
On Wed, 4 Jun 2025, 13:34 Even Rouault via PROJ, <proj at lists.osgeo.org>
wrote:
> Hi,
> Here's a release candidate for PROJ 9.6.2:
> https://download.osgeo.org/proj/proj-9.6.2RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.6.2RC1.zip
> Please test and report issues.
> # PROJ Release Notes
> ## 9.6.2
> ### Updates
> * Update EPSG to 12.013
> ### Bug Fixes
> * Database: change ESRI deprecated records back to their deprecated
> state (#4519)
> * ProjectedCRS::identify(): more robust identification of old ESRI names
> using _IntlFeet (#4518)
> * Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name
> (#4514)
> * proj_trans_bounds(): sample points within the source grid to avoid
> missing extent such as world-wide coverage from EPSG:4326 to ESRI:54099
> (Spilhaus) (#4513)
> * proj_trans_bounds(): avoid erroring out, in some cases, when PJ*
> object is directly constructed from a PROJ pipeline (#4512)
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250604/51c62667/attachment.htm>
More information about the PROJ
