[PROJ] Motion: promote 9.6.2RC1 as final 9.6.2 (Re: PROJ 9.6.2 RC1 available)
Even Rouault even.rouault at spatialys.com
Wed Jun 4 23:16:03 PDT 2025
Starting with my +1,
Even
Le 04/06/2025 à 13:34, Even Rouault via PROJ a écrit :
> Hi,
> Here's a release candidate for PROJ 9.6.2:
> https://download.osgeo.org/proj/proj-9.6.2RC1.tar.gz
> https://download.osgeo.org/proj/proj-9.6.2RC1.zip
> Please test and report issues.
> # PROJ Release Notes
> ## 9.6.2
> ### Updates
> * Update EPSG to 12.013
> ### Bug Fixes
> * Database: change ESRI deprecated records back to their deprecated
> state (#4519)
> * ProjectedCRS::identify(): more robust identification of old ESRI
> names using _IntlFeet (#4518)
> * Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name
> (#4514)
> * proj_trans_bounds(): sample points within the source grid to avoid
> missing extent such as world-wide coverage from EPSG:4326 to
> ESRI:54099 (Spilhaus) (#4513)
> * proj_trans_bounds(): avoid erroring out, in some cases, when PJ*
> object is directly constructed from a PROJ pipeline (#4512)
> Even
http://www.spatialys.com
More information about the PROJ mailing list
