[PROJ] Motion: promote 9.6.2RC1 as final 9.6.2 (Re: PROJ 9.6.2 RC1 available)
Javier Jimenez Shaw
j1 at jimenezshaw.com
Thu Jun 5 00:16:58 PDT 2025
+1 Javier
On Thu, 5 Jun 2025, 08:41 Even Rouault via PROJ, <proj at lists.osgeo.org>
wrote:
> Hi,
> Starting with my +1,
> Even
> Le 04/06/2025 à 13:34, Even Rouault via PROJ a écrit :
> > Hi,
> > Here's a release candidate for PROJ 9.6.2:
> > https://download.osgeo.org/proj/proj-9.6.2RC1.tar.gz
> > https://download.osgeo.org/proj/proj-9.6.2RC1.zip
> > Please test and report issues.
> > # PROJ Release Notes
> > ## 9.6.2
> > ### Updates
> > * Update EPSG to 12.013
> > ### Bug Fixes
> > * Database: change ESRI deprecated records back to their deprecated
> > state (#4519)
> > * ProjectedCRS::identify(): more robust identification of old ESRI
> > names using _IntlFeet (#4518)
> > * Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name
> > (#4514)
> > * proj_trans_bounds(): sample points within the source grid to avoid
> > missing extent such as world-wide coverage from EPSG:4326 to
> > ESRI:54099 (Spilhaus) (#4513)
> > * proj_trans_bounds(): avoid erroring out, in some cases, when PJ*
> > object is directly constructed from a PROJ pipeline (#4512)
> > Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250605/f0b14130/attachment.htm>
More information about the PROJ
