[PROJ] Motion: promote 9.6.2RC1 as final 9.6.2 (Re: PROJ 9.6.2 RC1 available)
    Kristian Evers
    kristian at evers.dev
    Thu Jun  5 00:23:54 PDT 2025
+1 Kristian
> On 5 Jun 2025, at 09.16, Javier Jimenez Shaw via PROJ <proj at lists.osgeo.org> wrote:
> +1 Javier
> On Thu, 5 Jun 2025, 08:41 Even Rouault via PROJ, <proj at lists.osgeo.org> wrote:
>> Hi,
>> Starting with my +1,
>> Even
>> Le 04/06/2025 à 13:34, Even Rouault via PROJ a écrit :
>>> Hi,
>>> Here's a release candidate for PROJ 9.6.2:
>>> https://download.osgeo.org/proj/proj-9.6.2RC1.tar.gz
>>> https://download.osgeo.org/proj/proj-9.6.2RC1.zip
>>> Please test and report issues.
>>> # PROJ Release Notes
>>> ## 9.6.2
>>> ### Updates
>>> * Update EPSG to 12.013
>>> ### Bug Fixes
>>> * Database: change ESRI deprecated records back to their deprecated
>>> state (#4519)
>>> * ProjectedCRS::identify(): more robust identification of old ESRI
>>> names using _IntlFeet (#4518)
>>> * Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name
>>> (#4514)
>>> * proj_trans_bounds(): sample points within the source grid to avoid
>>> missing extent such as world-wide coverage from EPSG:4326 to
>>> ESRI:54099 (Spilhaus) (#4513)
>>> * proj_trans_bounds(): avoid erroring out, in some cases, when PJ*
>>> object is directly constructed from a PROJ pipeline (#4512)
>>> Even
>> [http://www.spatialys.com](http://www.spatialys.com/)
>> My software is free, but my time generally not.
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250605/4204eb9e/attachment.htm>
More information about the PROJ
