[PROJ] Motion: promote 9.6.2RC1 as final 9.6.2 (Re: PROJ 9.6.2 RC1 available)
Howard Butler howard at hobu.co
Thu Jun 5 05:28:45 PDT 2025
+1 Howard
Release early and often! (Thanks for cleaning this one up quickly)
> On Jun 5, 2025, at 7:13 AM, Alan Snow via PROJ <proj at lists.osgeo.org> wrote:
> +1 Alan
> On Thu, Jun 5, 2025, 2:16 AM Even Rouault via PROJ <proj at lists.osgeo.org <mailto:proj at lists.osgeo.org>> wrote:
>> Hi,
>> Starting with my +1,
>> Even
>> Le 04/06/2025 à 13:34, Even Rouault via PROJ a écrit :
>> > Hi,
>> > Here's a release candidate for PROJ 9.6.2:
>> > https://download.osgeo.org/proj/proj-9.6.2RC1.tar.gz
>> > https://download.osgeo.org/proj/proj-9.6.2RC1.zip
>> > Please test and report issues.
>> > # PROJ Release Notes
>> > ## 9.6.2
>> > ### Updates
>> > * Update EPSG to 12.013
>> > ### Bug Fixes
>> > * Database: change ESRI deprecated records back to their deprecated
>> > state (#4519)
>> > * ProjectedCRS::identify(): more robust identification of old ESRI
>> > names using _IntlFeet (#4518)
>> > * Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name
>> > (#4514)
>> > * proj_trans_bounds(): sample points within the source grid to avoid
>> > missing extent such as world-wide coverage from EPSG:4326 to
>> > ESRI:54099 (Spilhaus) (#4513)
>> > * proj_trans_bounds(): avoid erroring out, in some cases, when PJ*
>> > object is directly constructed from a PROJ pipeline (#4512)
>> > Even
>> http://www.spatialys.com <http://www.spatialys.com/>
>> My software is free, but my time generally not.
>> PROJ mailing list
>> PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250605/daaa6261/attachment.htm>
More information about the PROJ mailing list
