[PROJ] Motion: promote 9.6.2RC1 as final 9.6.2 (Re: PROJ 9.6.2 RC1 available)
Even Rouault even.rouault at spatialys.com
Fri Jun 6 05:08:25 PDT 2025
Motion passed with +1 from PSC members JavierJS, KristianE, CharlesK,
AlanS, HowardB and I
Le 05/06/2025 à 08:16, Even Rouault via PROJ a écrit :
> Hi,
> Starting with my +1,
> Even
> Le 04/06/2025 à 13:34, Even Rouault via PROJ a écrit :
>> Hi,
>> Here's a release candidate for PROJ 9.6.2:
>> https://download.osgeo.org/proj/proj-9.6.2RC1.tar.gz
>> https://download.osgeo.org/proj/proj-9.6.2RC1.zip
>> Please test and report issues.
>> # PROJ Release Notes
>> ## 9.6.2
>> ### Updates
>> * Update EPSG to 12.013
>> ### Bug Fixes
>> * Database: change ESRI deprecated records back to their deprecated
>> state (#4519)
>> * ProjectedCRS::identify(): more robust identification of old ESRI
>> names using _IntlFeet (#4518)
>> * Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name
>> (#4514)
>> * proj_trans_bounds(): sample points within the source grid to avoid
>> missing extent such as world-wide coverage from EPSG:4326 to
>> ESRI:54099 (Spilhaus) (#4513)
>> * proj_trans_bounds(): avoid erroring out, in some cases, when PJ*
>> object is directly constructed from a PROJ pipeline (#4512)
>> Even
http://www.spatialys.com
More information about the PROJ mailing list
