[PROJ] PROJ 9.6.2 is released
Even Rouault
even.rouault at spatialys.com
Fri Jun 6 05:21:28 PDT 2025
On behalf of the PROJ team I am happy to announce the release of PROJ 9.6.2
The PROJ release includes updates to the the database contents, as well as a number of bug fixes. See the release notes below.
Download the archives here:
http://download.osgeo.org/proj/proj-9.6.2.tar.gz
http://download.osgeo.org/proj/proj-9.6.2.zip
Even
# PROJ Release Notes
## 9.6.2
### Updates
* Update EPSG to 12.013
### Bug Fixes
* Database: change ESRI deprecated records back to their deprecated state (#4519)
* ProjectedCRS::identify(): more robust identification of old ESRI names using _IntlFeet (#4518)
* Fix issue related to D_Unknown_based_on_WGS_84_ellipsoid datum name (#4514)
* proj_trans_bounds(): sample points within the source grid to avoid missing extent such as world-wide coverage from EPSG:4326 to ESRI:54099 (Spilhaus) (#4513)
* proj_trans_bounds(): avoid erroring out, in some cases, when PJ* object is directly constructed from a PROJ pipeline (#4512)
http://www.spatialys.com
More information about the PROJ
