[PROJ] PROJ 9.6.0RC2
Roger Bivand
Roger.Bivand at nhh.no
Wed Mar 12 07:53:49 PDT 2025
With RC2 and GDAL 3.10.2, when running ctest in the GDAL build directory, I'm seeing (updated Fedora 41):
The following tests FAILED:
35 - test-osr-set-proj-search-paths (Failed)
40 - autotest_gdrivers (Failed)
43 - autotest_osr (Failed)
Errors while running CTest
RC1 had these problems too, but I waited to try ctest from GDAL 3.10.2 on my desktop todat rather than my laptop when RC1 was posted as more tests are active on the desktop. Should this cause concern? The failures include:
[ RUN ] test_osr_set_proj_search_paths.test
/home/rsb/topics/gdal/gdal-3.10.2/autotest/cpp/test_osr_set_proj_search_paths.cpp:35: Failure
Expected: (ret) != (0), actual: 0 vs 0
def test_jp2metadata_1():
ds = gdal.Open("data/jpeg2000/erdas_foo.jp2")
wkt = ds.GetProjectionRef()
gt = ds.GetGeoTransform()
> assert wkt.startswith('PROJCS["ETRS89')
E assert False
E + where False = <built-in method startswith of str object at 0x55cf18512d90>('PROJCS["ETRS89')
E + where <built-in method startswith of str object at 0x55cf18512d90> = 'PROJCS["EUREF-FIN / TM35FIN(E,N)",GEOGCS["EUREF-FIN",DATUM["EUREF-FIN",SPHEROID["GRS 1980",6378137,298.257222101,AUTH...ing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","3067"]]'.startswith
/home/rsb/topics/gdal/gdal-3.10.2/build/autotest/gdrivers/jp2metadata.py:44: AssertionError
FAILED gdrivers/jp2metadata.py::test_jp2metadata_1 - assert False
/home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:1773: AssertionError
/home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:1806: AssertionError
/home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:2027: AssertionError
FAILED osr/osr_basic.py::test_SetPROJSearchPath - assert True == False
FAILED osr/osr_basic.py::test_Set_PROJ_DATA_config_option - assert True == False
FAILED osr/osr_basic.py::test_Set_PROJ_DATA_config_option_sub_proccess_config_option_ko
FAILED osr/osr_basic.py::test_osr_basic_is_dynamic - AssertionError: assert n...
Please indicate whether the full output of ctest --rerun-failed --output-on-failure would be useful.
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
More information about the PROJ
