[PROJ] PROJ 9.6.0RC2
Even Rouault even.rouault at spatialys.com
Wed Mar 12 08:15:24 PDT 2025
Roger,
I could reproduce the jp2metadata.py:44 and osr_basic.py:2027 errors,
and I've fixed them with
https://github.com/OSGeo/gdal/commit/49ef64108b6875e5b90a4fb6cadd089e84fe53c1
I don't know why you get the other errors. They all seem to be related
to setting PROJ data. Isn't there some ghost PROJ_LIB variable set in
your environment ?
Even
Le 12/03/2025 à 15:53, Roger Bivand via PROJ a écrit :
> With RC2 and GDAL 3.10.2, when running ctest in the GDAL build directory, I'm seeing (updated Fedora 41):
> The following tests FAILED:
>           35 - test-osr-set-proj-search-paths (Failed)
>           40 - autotest_gdrivers (Failed)
>           43 - autotest_osr (Failed)
> Errors while running CTest
> RC1 had these problems too, but I waited to try ctest from GDAL 3.10.2 on my desktop todat rather than my laptop when RC1 was posted as more tests are active on the desktop. Should this cause concern? The failures include:
> [ RUN      ] test_osr_set_proj_search_paths.test
> /home/rsb/topics/gdal/gdal-3.10.2/autotest/cpp/test_osr_set_proj_search_paths.cpp:35: Failure
> Expected: (ret) != (0), actual: 0 vs 0
>      def test_jp2metadata_1():
>          ds = gdal.Open("data/jpeg2000/erdas_foo.jp2")
>          wkt = ds.GetProjectionRef()
>          gt = ds.GetGeoTransform()
>>        assert wkt.startswith('PROJCS["ETRS89')
> E       assert False
> E        +  where False = <built-in method startswith of str object at 0x55cf18512d90>('PROJCS["ETRS89')
> E        +    where <built-in method startswith of str object at 0x55cf18512d90> = 'PROJCS["EUREF-FIN / TM35FIN(E,N)",GEOGCS["EUREF-FIN",DATUM["EUREF-FIN",SPHEROID["GRS 1980",6378137,298.257222101,AUTH...ing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","3067"]]'.startswith
> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/gdrivers/jp2metadata.py:44: AssertionError
> FAILED gdrivers/jp2metadata.py::test_jp2metadata_1 - assert False
> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:1773: AssertionError
> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:1806: AssertionError
> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:2027: AssertionError
> FAILED osr/osr_basic.py::test_SetPROJSearchPath - assert True == False
> FAILED osr/osr_basic.py::test_Set_PROJ_DATA_config_option - assert True == False
> FAILED osr/osr_basic.py::test_Set_PROJ_DATA_config_option_sub_proccess_config_option_ko
> FAILED osr/osr_basic.py::test_osr_basic_is_dynamic - AssertionError: assert n...
> Please indicate whether the full output of ctest --rerun-failed --output-on-failure would be useful.
> Roger
> Roger Bivand
> Emeritus Professor
> Norwegian School of Economics
> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
> Roger.Bivand at nhh.no
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
