[PROJ] PROJ 9.6.0RC2
Roger Bivand
Roger.Bivand at nhh.no
Wed Mar 12 09:56:35 PDT 2025
Even,
On Wed, 12 Mar 2025, Even Rouault wrote:
> Roger,
> I could reproduce the jp2metadata.py:44 and osr_basic.py:2027 errors, and
> I've fixed them with
> https://github.com/OSGeo/gdal/commit/49ef64108b6875e5b90a4fb6cadd089e84fe53c1
> I don't know why you get the other errors. They all seem to be related to
> setting PROJ data. Isn't there some ghost PROJ_LIB variable set in your
> environment ?
None that echo $PROJ_LIB or echo $PROJ_DATA show, or
unset PROJ_LIB ; ctest for example. Should I add the complete output of
running ctest to this thread (490 lines)?
Roger
> Even
> Le 12/03/2025 à 15:53, Roger Bivand via PROJ a écrit :
>> With RC2 and GDAL 3.10.2, when running ctest in the GDAL build directory,
>> I'm seeing (updated Fedora 41):
>> The following tests FAILED:
>> 35 - test-osr-set-proj-search-paths (Failed)
>> 40 - autotest_gdrivers (Failed)
>> 43 - autotest_osr (Failed)
>> Errors while running CTest
>> RC1 had these problems too, but I waited to try ctest from GDAL 3.10.2 on
>> my desktop todat rather than my laptop when RC1 was posted as more tests
>> are active on the desktop. Should this cause concern? The failures
>> include:
>> [ RUN ] test_osr_set_proj_search_paths.test
>> /home/rsb/topics/gdal/gdal-3.10.2/autotest/cpp/test_osr_set_proj_search_paths.cpp:35:
>> Failure
>> Expected: (ret) != (0), actual: 0 vs 0
>> def test_jp2metadata_1():
>> ds = gdal.Open("data/jpeg2000/erdas_foo.jp2")
>> wkt = ds.GetProjectionRef()
>> gt = ds.GetGeoTransform()
>>> assert wkt.startswith('PROJCS["ETRS89')
>> E assert False
>> E + where False = <built-in method startswith of str object at
>> 0x55cf18512d90>('PROJCS["ETRS89')
>> E + where <built-in method startswith of str object at
>> 0x55cf18512d90> = 'PROJCS["EUREF-FIN /
>> TM35FIN(E,N)",GEOGCS["EUREF-FIN",DATUM["EUREF-FIN",SPHEROID["GRS
>> 1980",6378137,298.257222101,AUTH...ing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Easting",EAST],AXIS["Northing",NORTH],AUTHORITY["EPSG","3067"]]'.startswith
>> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/gdrivers/jp2metadata.py:44:
>> AssertionError
>> FAILED gdrivers/jp2metadata.py::test_jp2metadata_1 - assert False
>> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:1773:
>> AssertionError
>> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:1806:
>> AssertionError
>> /home/rsb/topics/gdal/gdal-3.10.2/build/autotest/osr/osr_basic.py:2027:
>> AssertionError
>> FAILED osr/osr_basic.py::test_SetPROJSearchPath - assert True == False
>> FAILED osr/osr_basic.py::test_Set_PROJ_DATA_config_option - assert True ==
>> False
>> FAILED
>> osr/osr_basic.py::test_Set_PROJ_DATA_config_option_sub_proccess_config_option_ko
>> FAILED osr/osr_basic.py::test_osr_basic_is_dynamic - AssertionError:
>> assert n...
>> Please indicate whether the full output of ctest --rerun-failed
>> --output-on-failure would be useful.
>> Roger
>> Roger Bivand
>> Emeritus Professor
>> Norwegian School of Economics
>> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
More information about the PROJ
