[PROJ] PROJ 9.6.0RC2
Even Rouault
even.rouault at spatialys.com
Wed Mar 12 11:05:16 PDT 2025
ok, on second thought, I figured the issue. I assume you have statically
linked PROJ or have explicitly enabled EMBED_RESOURCE_FILES=ON when
building it (cf
https://proj.org/en/latest/install.html#cmdoption-arg-EMBED_RESOURCE_FILES).
At least I can reproduce those test failures with
EMBED_RESOURCE_FILES=ON. Those tests aren't compatible with that
configuration of PROJ. Ideally we should have some mechanism to skip
them, but that would require that PROJ exposes how it has been built. In
any case, this isn't something to worry about, just a testing issue.
Le 12/03/2025 à 18:53, Roger Bivand a écrit :
> On Wed, 12 Mar 2025, Even Rouault wrote:
>>>>> unset PROJ_LIB ; ctest for example. Should I add the complete
>>>>> output of
>>>>> running ctest to this thread (490 lines)?
>>>> maybe paste it some paste service (github gist, etc) and link it
>>>> to it.
>>> https://gist.github.com/rsbivand/09bd9e998889a44d2eecbb842c1a5168
>> sorry, no clue. I doubt this is 9.6.0 related
> There are no such errors with PROJ 9.5.1 and GDAL 3.10.2 on the same
> platform, so the only obvious change is building GDAL with 9.5.1 or
> 9.6.0RC2. That is why I waited, as the airport internet I was
> depending on before I got to my desktop could have been a factor. For
> 9.5.1:
> Start 35: test-osr-set-proj-search-paths
> 35/46 Test #35: test-osr-set-proj-search-paths ... Passed 0.12 sec
> Start 40: autotest_gdrivers
> 40/46 Test #40: autotest_gdrivers ................ Passed 125.56 sec
> Start 43: autotest_osr
> 43/46 Test #43: autotest_osr ..................... Passed 4.14 sec
> Roger
http://www.spatialys.com
More information about the PROJ
