[PROJ] PROJ 9.6.0RC2
    Roger Bivand
    Roger.Bivand at nhh.no
    Wed Mar 12 12:28:09 PDT 2025
On Wed, 12 Mar 2025, Even Rouault wrote:
> ok, on second thought, I figured the issue. I assume you have statically
> linked PROJ or have explicitly enabled EMBED_RESOURCE_FILES=ON when building
> it (cf
> https://proj.org/en/latest/install.html#cmdoption-arg-EMBED_RESOURCE_FILES).
> At least I can reproduce those test failures with EMBED_RESOURCE_FILES=ON.
In proj-9.6.0/build/CMakeCache.txt created by naked cmake .., I see:
//Whether resource files (limited to proj.db) should be embedded
// into the PROJ library
EMBED_RESOURCE_FILES:BOOL=ON
//Whether the PROJ_DATA_PATH should be embedded
EMBED_PROJ_DATA_PATH:BOOL=ON
//Directory that contains .tif, .json or .pol files to embed into
// libproj
EMBED_RESOURCE_DIRECTORY:PATH=
//Whether embedded resource files (limited to proj.db) should be
// used (should nominally be used together with EMBED_RESOURCE_FILES=ON,
// otherwise this will result in non-functional builds)
USE_ONLY_EMBEDDED_RESOURCE_FILES:BOOL=OFF
and lib contains only libproj.so.25.9.6.0 and its links, so not a static
build. How did EMBED_RESOURCE_FILES get turned on by default, but with
USE_ONLY_EMBEDDED_RESOURCE_FILES off?
but no EMBED_RESOURCE_FILES entry at all in 9.5.1, which only has
Trying again with 9.6.0 and
cmake -DEMBED_RESOURCE_FILES=OFF ..
gives
EMBED_RESOURCE_FILES:BOOL=OFF
so trying to re-build everything - I don't use ccache, and am using
separate build directories, it'll take a little while.
Roger
> Those tests aren't compatible with that configuration of PROJ. Ideally we
> should have some mechanism to skip them, but that would require that PROJ
> exposes how it has been built. In any case, this isn't something to worry
> about, just a testing issue.
>>>>>>    unset PROJ_LIB ; ctest for example. Should I add the complete output
>>>>>>  of
>>>>>>    running ctest to this thread (490 lines)?
>>>>>   maybe paste it some paste service (github gist, etc) and link it to
>>>>>  it.
>>>>   https://gist.github.com/rsbivand/09bd9e998889a44d2eecbb842c1a5168
>>>  sorry, no clue. I doubt this is 9.6.0 related
>>  There are no such errors with PROJ 9.5.1 and GDAL 3.10.2 on the same
>>  platform, so the only obvious change is building GDAL with 9.5.1 or
>>  9.6.0RC2. That is why I waited, as the airport internet I was depending on
>>  before I got to my desktop could have been a factor. For 9.5.1:
>>        Start 35: test-osr-set-proj-search-paths
>>  35/46 Test #35: test-osr-set-proj-search-paths ...   Passed 0.12 sec
>>        Start 40: autotest_gdrivers
>>  40/46 Test #40: autotest_gdrivers ................   Passed 125.56 sec
>>        Start 43: autotest_osr
>>  43/46 Test #43: autotest_osr .....................   Passed 4.14 sec
>>  Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
More information about the PROJ
