[PROJ] PROJ 9.6.0RC2
    Roger Bivand
    Roger.Bivand at nhh.no
    Wed Mar 12 12:36:32 PDT 2025
On Wed, 12 Mar 2025, Roger Bivand wrote:
> On Wed, 12 Mar 2025, Even Rouault wrote:
>>  ok, on second thought, I figured the issue. I assume you have statically
>>  linked PROJ or have explicitly enabled EMBED_RESOURCE_FILES=ON when
>>  building it (cf
>>  https://proj.org/en/latest/install.html#cmdoption-arg-EMBED_RESOURCE_FILES).
>>  At least I can reproduce those test failures with EMBED_RESOURCE_FILES=ON.
> In proj-9.6.0/build/CMakeCache.txt created by naked cmake .., I see:
> //Whether resource files (limited to proj.db) should be embedded
> // into the PROJ library
> EMBED_RESOURCE_FILES:BOOL=ON
> //Whether the PROJ_DATA_PATH should be embedded
> EMBED_PROJ_DATA_PATH:BOOL=ON
> //Directory that contains .tif, .json or .pol files to embed into
> // libproj
> EMBED_RESOURCE_DIRECTORY:PATH=
> //Whether embedded resource files (limited to proj.db) should be
> // used (should nominally be used together with EMBED_RESOURCE_FILES=ON,
> // otherwise this will result in non-functional builds)
> USE_ONLY_EMBEDDED_RESOURCE_FILES:BOOL=OFF
> and lib contains only libproj.so.25.9.6.0 and its links, so not a static
> build.
lib/libproj.so.25.9.6.0 is 14.9 MB
> How did EMBED_RESOURCE_FILES get turned on by default, but with
> USE_ONLY_EMBEDDED_RESOURCE_FILES off?
> but no EMBED_RESOURCE_FILES entry at all in 9.5.1, which only has
> Trying again with 9.6.0 and
> cmake -DEMBED_RESOURCE_FILES=OFF ..
> gives
> EMBED_RESOURCE_FILES:BOOL=OFF
> so trying to re-build everything - I don't use ccache, and am using separate
> build directories, it'll take a little while.
lib/libproj.so.25.9.6.0 is 5.4 MB
Now rebuilding GDAL ...
> Roger
>>  Those tests aren't compatible with that configuration of PROJ. Ideally we
>>  should have some mechanism to skip them, but that would require that PROJ
>>  exposes how it has been built. In any case, this isn't something to worry
>>  about, just a testing issue.
>>>>>>>     unset PROJ_LIB ; ctest for example. Should I add the complete
>>>>>>>   output
>>>>>>>   of
>>>>>>>     running ctest to this thread (490 lines)?
>>>>>>    maybe paste it some paste service (github gist, etc) and link it to
>>>>>>   it.
>>>>>    https://gist.github.com/rsbivand/09bd9e998889a44d2eecbb842c1a5168
>>>>   sorry, no clue. I doubt this is 9.6.0 related
>>>   There are no such errors with PROJ 9.5.1 and GDAL 3.10.2 on the same
>>>   platform, so the only obvious change is building GDAL with 9.5.1 or
>>>   9.6.0RC2. That is why I waited, as the airport internet I was depending
>>>   on
>>>   before I got to my desktop could have been a factor. For 9.5.1:
>>>         Start 35: test-osr-set-proj-search-paths
>>>   35/46 Test #35: test-osr-set-proj-search-paths ...   Passed 0.12 sec
>>>         Start 40: autotest_gdrivers
>>>   40/46 Test #40: autotest_gdrivers ................   Passed 125.56 sec
>>>         Start 43: autotest_osr
>>>   43/46 Test #43: autotest_osr .....................   Passed 4.14 sec
>>>   Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
More information about the PROJ
