[PROJ] PROJ 9.6.0RC2
Roger Bivand
Roger.Bivand at nhh.no
Wed Mar 12 13:27:22 PDT 2025
>> On Wed, 12 Mar 2025, Even Rouault wrote:
>>> ok, on second thought, I figured the issue. I assume you have statically
>>> linked PROJ or have explicitly enabled EMBED_RESOURCE_FILES=ON when
>>> building it (cf
>>> https://proj.org/en/latest/install.html#cmdoption-arg-EMBED_RESOURCE_FILES).
>>> At least I can reproduce those test failures with
>>> EMBED_RESOURCE_FILES=ON.
>> In proj-9.6.0/build/CMakeCache.txt created by naked cmake .., I see:
>> //Whether resource files (limited to proj.db) should be embedded
>> // into the PROJ library
>> EMBED_RESOURCE_FILES:BOOL=ON
>> //Whether the PROJ_DATA_PATH should be embedded
>> EMBED_PROJ_DATA_PATH:BOOL=ON
>> //Directory that contains .tif, .json or .pol files to embed into
>> // libproj
>> EMBED_RESOURCE_DIRECTORY:PATH=
>> //Whether embedded resource files (limited to proj.db) should be
>> // used (should nominally be used together with EMBED_RESOURCE_FILES=ON,
>> // otherwise this will result in non-functional builds)
>> USE_ONLY_EMBEDDED_RESOURCE_FILES:BOOL=OFF
>> and lib contains only libproj.so.25.9.6.0 and its links, so not a static
>> build.
> lib/libproj.so.25.9.6.0 is 14.9 MB
>> How did EMBED_RESOURCE_FILES get turned on by default, but with
>> USE_ONLY_EMBEDDED_RESOURCE_FILES off?
>> but no EMBED_RESOURCE_FILES entry at all in 9.5.1, which only has
>> Trying again with 9.6.0 and
>> cmake -DEMBED_RESOURCE_FILES=OFF ..
>> gives
>> EMBED_RESOURCE_FILES:BOOL=OFF
>> so trying to re-build everything - I don't use ccache, and am using
>> separate build directories, it'll take a little while.
> lib/libproj.so.25.9.6.0 is 5.4 MB
> Now rebuilding GDAL ...
The following tests FAILED:
40 - autotest_gdrivers (Failed)
43 - autotest_osr (Failed)
Errors while running CTest
and these are the tests patched in
https://github.com/OSGeo/gdal/commit/49ef64108b6875e5b90a4fb6cadd089e84fe53c1
- details added to gist.
The logic in CMakeLists.txt at line 371 looks OK:
if (NOT BUILD_SHARED_LIBS)
set(DEFAULT_EMBED_RESOURCE_FILES ON)
else()
set(DEFAULT_EMBED_RESOURCE_FILES OFF)
endif()
but in the default shared library case turns the embedding option on
silently.
>> Roger
>>> Those tests aren't compatible with that configuration of PROJ. Ideally
>>> we
>>> should have some mechanism to skip them, but that would require that
>>> PROJ
>>> exposes how it has been built. In any case, this isn't something to
>>> worry
>>> about, just a testing issue.
>>>>>>>> unset PROJ_LIB ; ctest for example. Should I add the complete
>>>>>>>> output
>>>>>>>> of
>>>>>>>> running ctest to this thread (490 lines)?
>>>>>>> maybe paste it some paste service (github gist, etc) and link it
>>>>>>> to
>>>>>>> it.
>>>>>> https://gist.github.com/rsbivand/09bd9e998889a44d2eecbb842c1a5168
>>>>> sorry, no clue. I doubt this is 9.6.0 related
>>>> There are no such errors with PROJ 9.5.1 and GDAL 3.10.2 on the same
>>>> platform, so the only obvious change is building GDAL with 9.5.1 or
>>>> 9.6.0RC2. That is why I waited, as the airport internet I was
>>>> depending
>>>> on
>>>> before I got to my desktop could have been a factor. For 9.5.1:
>>>> Start 35: test-osr-set-proj-search-paths
>>>> 35/46 Test #35: test-osr-set-proj-search-paths ... Passed 0.12 sec
>>>> Start 40: autotest_gdrivers
>>>> 40/46 Test #40: autotest_gdrivers ................ Passed 125.56 sec
>>>> Start 43: autotest_osr
>>>> 43/46 Test #43: autotest_osr ..................... Passed 4.14 sec
>>>> Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
More information about the PROJ
