[PROJ] PROJ 9.6.0RC2
Even Rouault even.rouault at spatialys.com
Wed Mar 12 13:28:39 PDT 2025
Roger,
good catch. Thanks for your patient testing. I could reproduce on a
fresh build directory when BUILD_SHARED_LIBS was not set at all. There
was an ordering issue between setting the default value of
BUILD_SHARED_LIBS and EMBED_RESOURCE_FILES that led EMBED_RESOURCE_FILES
to be set to ON in that situation.
Fixed per https://github.com/OSGeo/PROJ/pull/4422
Even
Le 12/03/2025 à 20:36, Roger Bivand a écrit :
> On Wed, 12 Mar 2025, Roger Bivand wrote:
>> On Wed, 12 Mar 2025, Even Rouault wrote:
>>>  ok, on second thought, I figured the issue. I assume you have
>>> statically
>>>  linked PROJ or have explicitly enabled EMBED_RESOURCE_FILES=ON when
>>>  building it (cf
>>>  https://proj.org/en/latest/install.html#cmdoption-arg-EMBED_RESOURCE_FILES).
>>>  At least I can reproduce those test failures with
>>> EMBED_RESOURCE_FILES=ON.
>> In proj-9.6.0/build/CMakeCache.txt created by naked cmake .., I see:
>> //Whether resource files (limited to proj.db) should be embedded
>> // into the PROJ library
>> EMBED_RESOURCE_FILES:BOOL=ON
>> //Whether the PROJ_DATA_PATH should be embedded
>> EMBED_PROJ_DATA_PATH:BOOL=ON
>> //Directory that contains .tif, .json or .pol files to embed into
>> // libproj
>> EMBED_RESOURCE_DIRECTORY:PATH=
>> //Whether embedded resource files (limited to proj.db) should be
>> // used (should nominally be used together with EMBED_RESOURCE_FILES=ON,
>> // otherwise this will result in non-functional builds)
>> USE_ONLY_EMBEDDED_RESOURCE_FILES:BOOL=OFF
>> and lib contains only libproj.so.25.9.6.0 and its links, so not a
>> static build.
> lib/libproj.so.25.9.6.0 is 14.9 MB
>> How did EMBED_RESOURCE_FILES get turned on by default, but with
>> USE_ONLY_EMBEDDED_RESOURCE_FILES off?
>> but no EMBED_RESOURCE_FILES entry at all in 9.5.1, which only has
>> Trying again with 9.6.0 and
>> cmake -DEMBED_RESOURCE_FILES=OFF ..
>> gives
>> EMBED_RESOURCE_FILES:BOOL=OFF
>> so trying to re-build everything - I don't use ccache, and am using
>> separate build directories, it'll take a little while.
> lib/libproj.so.25.9.6.0 is 5.4 MB
> Now rebuilding GDAL ...
>> Roger
>>>  Those tests aren't compatible with that configuration of PROJ.
>>> Ideally we
>>>  should have some mechanism to skip them, but that would require
>>> that PROJ
>>>  exposes how it has been built. In any case, this isn't something to
>>> worry
>>>  about, just a testing issue.
>>>>>>>>     unset PROJ_LIB ; ctest for example. Should I add the complete
>>>>>>>>   output
>>>>>>>>   of
>>>>>>>>     running ctest to this thread (490 lines)?
>>>>>>>    maybe paste it some paste service (github gist, etc) and link
>>>>>>> it to
>>>>>>>   it.
>>>>>>  https://gist.github.com/rsbivand/09bd9e998889a44d2eecbb842c1a5168
>>>>>   sorry, no clue. I doubt this is 9.6.0 related
>>>>   There are no such errors with PROJ 9.5.1 and GDAL 3.10.2 on the same
>>>>   platform, so the only obvious change is building GDAL with 9.5.1 or
>>>>   9.6.0RC2. That is why I waited, as the airport internet I was
>>>> depending
>>>>   on
>>>>   before I got to my desktop could have been a factor. For 9.5.1:
>>>>         Start 35: test-osr-set-proj-search-paths
>>>>   35/46 Test #35: test-osr-set-proj-search-paths ... Passed 0.12 sec
>>>>         Start 40: autotest_gdrivers
>>>>   40/46 Test #40: autotest_gdrivers ................ Passed 125.56 sec
>>>>         Start 43: autotest_osr
>>>>   43/46 Test #43: autotest_osr ..................... Passed 4.14 sec
>>>>   Roger
http://www.spatialys.com
More information about the PROJ mailing list
