[PROJ] Fwd: PROJ 9.6.0RC3
Roger Bivand Roger.Bivand at nhh.no
Fri Mar 14 05:47:57 PDT 2025
Standard build with RC3 OK (for manual build on Fedora 41 on which RC2
flipped to embedded resource file without this being chosen).
Only one regression among 1100 R packages using PROJ/GDAL through the R
packages sf and terra is geofi, which compares the current definition of
EPSG:3067 with that from earlier PROJ/EPSG versions, and fails on
topological operations checking that CRS are the same where one object is
instantiated on-th-fly, and the one it is compared with was created and
serialized using an earlier PROJ/EPSG version:
https://github.com/rOpenGov/geofi/issues/52. geofi will need to condition
on PROJ/EPSG version.
Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
More information about the PROJ mailing list
