[PROJ] Fwd: PROJ 9.6.0RC3
    Javier Jimenez Shaw
    j1 at jimenezshaw.com
    Fri Mar 14 05:54:36 PDT 2025
That makes sense, because the definition of of EPSG:3067 changed. Before
was based on ETRS89, now on EUREF-FIN.
On Fri, 14 Mar 2025 at 13:48, Roger Bivand via PROJ <proj at lists.osgeo.org>
wrote:
> Standard build with RC3 OK (for manual build on Fedora 41 on which RC2
> flipped to embedded resource file without this being chosen).
> Only one regression among 1100 R packages using PROJ/GDAL through the R
> packages sf and terra is geofi, which compares the current definition of
> EPSG:3067 with that from earlier PROJ/EPSG versions, and fails on
> topological operations checking that CRS are the same where one object is
> instantiated on-th-fly, and the one it is compared with was created and
> serialized using an earlier PROJ/EPSG version:
> https://github.com/rOpenGov/geofi/issues/52. geofi will need to condition
> on PROJ/EPSG version.
> Roger
> Roger Bivand
> Emeritus Professor
> Department of Economics, Norwegian School of Economics,
> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
> e-mail: Roger.Bivand at nhh.no
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250314/f1b872cd/attachment.htm>
More information about the PROJ
