[PROJ] Fwd: PROJ 9.6.0RC3
Roger Bivand
Roger.Bivand at nhh.no
Fri Mar 14 06:03:50 PDT 2025
On Fri, 14 Mar 2025, Javier Jimenez Shaw wrote:
> You don't often get email from j1 at jimenezshaw.com. Learn why this is
> important<https://aka.ms/LearnAboutSenderIdentification>
> That makes sense, because the definition of of EPSG:3067 changed. Before
> was based on ETRS89, now on EUREF-FIN.
Yes, I reported this as it may be found by others using CRS for Finland,
and linked to an issue at the geofi repo. It may be that the Comprehensive
R Archive Network (CRAN) will update to 9.6.0 shortly after release on
some platforms, which would lead to geofi failing and having 14 days to
correct - at least now the maintainer will be forewarned if they track new
issues.
Some users think that EPSG are fixed, though.
Roger
> On Fri, 14 Mar 2025 at 13:48, Roger Bivand via PROJ <proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>> wrote:
> Standard build with RC3 OK (for manual build on Fedora 41 on which RC2
> flipped to embedded resource file without this being chosen).
> Only one regression among 1100 R packages using PROJ/GDAL through the R
> packages sf and terra is geofi, which compares the current definition of
> EPSG:3067 with that from earlier PROJ/EPSG versions, and fails on
> topological operations checking that CRS are the same where one object is
> instantiated on-th-fly, and the one it is compared with was created and
> serialized using an earlier PROJ/EPSG version:
> https://github.com/rOpenGov/geofi/issues/52. geofi will need to condition
> on PROJ/EPSG version.
> Roger
> Roger Bivand
> Emeritus Professor
> Department of Economics, Norwegian School of Economics,
> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
> e-mail: Roger.Bivand at nhh.no<mailto:Roger.Bivand at nhh.no>
> PROJ mailing list
> PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/proj
Roger Bivand
Emeritus Professor
More information about the PROJ
