[PROJ] Request for NTv2 Grid Files for ED50, IGM95, and Monte Mario to RDN2008 Transformations
Even Rouault even.rouault at spatialys.com
Thu May 1 08:50:27 PDT 2025
Hello,
unfortunately we cannot help you. Those files are not available under an
open data license, and must be acquired for a fee with
https://www.igmi.org/en
Even
Le 01/05/2025 à 17:47, Sourabh Arora a écrit :
> Dear Sir,
> I hope this message finds you well.
> I am currently working on a geospatial project that requires accurate
> coordinate transformations for Italian geodetic systems using
> PROJ/GDAL on Windows. In particular, we require NTv2 grid files for
> the following transformations:
> 1.
>     ED50 to RDN2008
>     Grid: 35160622_47161840_E50_F00.gsb
> 2.
>     IGM95 to RDN2008
>     Grid: 35160622_47161840_F89_F00.gsb
> 3.
>     Grid: 35160622_47161840_R40_F00.gsb
> These grid files are referenced on EPSG and PROJ documentation but are
> not publicly available in the PROJ-data repository or through
> projsync. As these transformations are critical for our application’s
> spatial accuracy, I would kindly like to request access to these .gsb
> files.
> If there formal procedure I need to follow, I would be happy to comply.
> Please let me know if additional information is required regarding the
> area of interest or the intended usage.
> Thank you in advance for your time and support.
> Best regards,
> Sourabh Arora
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250501/004dbb1b/attachment.htm>
More information about the PROJ mailing list
