[PROJ] qgis 3.34.15 failure with proj 9.6.0, is a qgis issue, not a proj issue
Greg Troxel
gdt at lexort.com
Fri May 2 06:56:45 PDT 2025
The unique constraints insert failure issue was not the problem. That
happens with both 9.5.1 and 9.6.0.
The changed line in the build output is
Operation needs translation in QgsCoordinateReferenceSystemUtils::translateProjection: spilhaus
which is because
QString QgsCoordinateReferenceSystemUtils::translateProjection( const QString &projection )
lacks a pair of lines that look like this
if ( projection == QLatin1String( "gstmerc" ) )
return QObject::tr( "Gauss-Schreiber" );
for spilhaus.
These lines are present in git on release-3_40 and master.
All in all, it was a surprise to me, and perhaps it is to some of you,
that adding a projection in proj leads to a requirement to add code to
qgis.
More information about the PROJ
