[PROJ] geoid model + Helmert
    Lesparre, Jochem
    Jochem.Lesparre at kadaster.nl
    Sat May  3 09:46:57 PDT 2025
Greg Troxel wrote:
> A) Use the geoid model to get LHN95 height from the ETRS89 HAE, based on ETRS89 horizontal.
> B) Take the original ETRS89 LLh and Helmert transform to CH1903+, and then discard the h, and swap in the LHN95 H from step A.
> What I'm having trouble with is that for a station, I expect ETRS89 HAE and CH1903+ HAE to be different, and that therefore one has to do the
> A/B procedure above.
This is indeed the correct method, but this is not really possible with a single pipeline in PROJ. If two pipelines is not an option, one workaround is temporarily storing the height in the epoch field v_4. I don't like that, because we will publish a time-dependent transformation too.
 > I don't understand how that relates to "Undoing" the grid shift. Perhaps these are two ways of expressing the same thing and that's what the push/pop is all about.
This is another workaround, that we use. From global/regional to national/local datum (from bottom to top in the pipeline below): first apply the geoid model; save the height; undo the geoid model; apply the Helmert transformation; restore the saved height.
>From national/local to global/regional datum:
+proj=pipeline
+step +proj=push +v_3
+step +proj=cart +ellps=intl
+step +proj=helmert +x=... +y=... +z=... +rx=... +ry=... +rz=... +s=... +convention=coordinate_frame +exact
+step +proj=cart +inv +ellps=GRS80
+step +proj=vgridshift +grids=geoid.tif +omit_fwd
+step +proj=pop +v_3
+step +proj=vgridshift +inv +grids=geoid.tif
I hope this clarifies what is meant with undoing the vgridshift,
Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
More information about the PROJ
