[PROJ] spilhaus regresssion test failures
Greg Troxel
gdt at lexort.com
Sun May 4 07:32:19 PDT 2025
Javier Jimenez Shaw <j1 at jimenezshaw.com> writes:
> The failures in the roundtrip suggest that the problem is in the inverse
> function of the spilhaus projection.
> Part of the code used there was refactored end of March in master, and
> maybe the new code/formulation behaves better in NetBSD.
> Could you test master in your environment?
Thanks for the hint. I ran a build/check from git master, and got a
clean pass.
I guess we don't know if the problem was in the previous code, or it was
ok and triggers a NetBSD bug, but I would guess since you changed things
on master you think it's better and there's no need to dig into it.
17/68 Testing: spilhaus
17/68 Test: spilhaus
Command: "/n0/gdt/SOFTWARE/GEO/PROJ/proj/BUILD/bin/gie" "/n0/gdt/SOFTWARE/GEO/PROJ/proj/test/gie/spilhaus.gie"
Directory: /n0/gdt/SOFTWARE/GEO/PROJ/proj/test
"spilhaus" start time: May 04 10:17 EDT
Output:
Reading file '/n0/gdt/SOFTWARE/GEO/PROJ/proj/test/gie/spilhaus.gie'
total: 133 tests succeeded, 0 tests skipped, 0 tests failed.
<end of output>
Test time = 0.04 sec
Test Passed.
"spilhaus" end time: May 04 10:17 EDT
"spilhaus" time elapsed: 00:00:00
Output:
<end of output>
Test Passed.
You may be amused by this test failure:
Test 95 failed
/n0/gdt/SOFTWARE/GEO/PROJ/proj/BUILD/bin/projinfo completion projinfo --pivot-crs
Different stdout+stderr returned (+) than expected (-):
- always if_no_direct_transformation never EPSG: ESRI: IAU_2015: IGNF: NKG: NRCAN: OGC: PROJ:
+ always if_no_direct_transformation never EPSG: ESRI: IAU_2015: IGNF: NKG: NRCAN: NSRS: OGC: PROJ:
which is obviously not an actual bug -- I had your NSRS db hooked in via
PROJ_AUX_DB.
More information about the PROJ
