[PROJ] 9.6 runtime for Windows
Roger Oberholtzer roger.oberholtzer at gmail.com
Thu May 22 00:23:43 PDT 2025
Thanks for the info! I will now test if 9.6 contains a speed-up of
proj_factors(). Fingers crossed.
On Wed, May 21, 2025 at 9:05 PM Jürgen E. Fischer via PROJ <
proj at lists.osgeo.org> wrote:
> Hi Roger,
> On Wed, 21. May 2025 at 10:56:54 +0000, Roger Oberholtzer via PROJ wrote:
> > I was hoping to test the 9.6 release to see how it runs on Windows.
> Usually
> > the proj DLL is in
> https://download.osgeo.org/osgeo4w/v2/x86_64/release/proj
> > in a folder called something like proj96-runtime.  I see everything else
> I am
> > expecting for 9.6.0, but not this one critical part. Am I too early?
> The packaging was changed in response to proj not putting the minor version
> number into the DLL name (implying that that was done because the ABI of
> proj 9
> will be stable).
> So the package is now called proj9-runtime:
> https://download.osgeo.org/osgeo4w/v2/x86_64/release/proj/proj9-runtime/proj9-runtime-9.6.0-2.tar.bz2
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Roger Oberholtzer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250522/5f40c751/attachment.htm>
More information about the PROJ mailing list
