[PROJ] WKT CRS
Even Rouault
even.rouault at spatialys.com
Thu May 22 05:49:28 PDT 2025
Johem,
> Why the differences, and is there a correct way?
Both ways are correct. PROJ is supposed to follow the recommendations
given at paragraph 7.3.3 Identifier of
https://docs.ogc.org/is/18-010r11/18-010r11.pdf where there are lots of
rules for when it is recommended to include or omit identifiers.
> It seems to me that most of the information is redundant anyway, just
> the EPSG code could do: e.g. COMPOUNDCRS["Bonaire DPnet + Bonaire
> height",ID["EPSG",10764]]. What elements are mandatory and what not?
This is defined in the above mentionned WKT CRS standard.
> This is relevant to me because we might want to change the CONVERSION
> of some PROJCRSs in EPSG in the future without changing the ID of the
> PROJCRS. Omitting the CONVERSION and only mentioning the ID of the
> PROJCRS in the WKT therefore seems a saver choice for the metadata of
> geo-information. Is this allowed?
No. The idea of WKT CRS is that you should be able to make sense of the
definition without a geodetic database available. At least for the
purpose of doing geographic <--> projected coordinate conversions (in
the same datum)
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20250522/0d10f210/attachment-0001.htm>
More information about the PROJ
