[PROJ] PROJ 9.6.1RC1 & PROJ-data 1.22RC1
Greg Troxel
gdt at lexort.com
Sun May 25 16:41:24 PDT 2025
Probably not a big deal, but I saw an odd soname, and don't remember
seeing it in previous RCs, so mentioning it:
=> Checking file-check results for proj-9.6.1RC1nb2
ERROR: ************************************************************
ERROR: The following files are in the PLIST but not in /tmp/work/geography/proj/work/.destdir/usr/pkg:
ERROR: /tmp/work/geography/proj/work/.destdir/usr/pkg/lib/libproj.so.25.9.6.1RC1
ERROR: The following files are in /tmp/work/geography/proj/work/.destdir/usr/pkg but not in the PLIST:
*** Error code 1
I get it that this will likely go away in release, but I had the
impression proj had the "build release as if real, and rename the
distfile" strategy vs the "build release with rc in the version"
strategy.
Other than that, all seemed good; I was able to delete 3 patches from
9.6.0 whose fixes were merged into 9.6.1. 'make check' passed on NetBSD
10 amd64.
More information about the PROJ
