[PROJ] proj.db in a cross compilation
Even Rouault even.rouault at spatialys.com
Mon Nov 10 16:13:34 PST 2025
Hi Javier,
the "key" is to have a sqlite3 executable for the host architecture
(that you can point to with the EXE_SQLITE3 CMake variable), and the
libsqlite3 library for the target one.
For example the GDAL CI has an Android setup at
https://github.com/OSGeo/gdal/blob/master/.github/workflows/android_cmake/start.sh#L45
(note that is likely not the most canonical way of setting up an Android
cross compilation, but at least it works...)
Even
Le 11/11/2025 à 00:58, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> I am trying to compile PROJ in emscripten (inside an ubuntu docker image).
> How do I produce proj.db?
> Any recommended compile options or steps?
> I thought there were some workflows cross-compiling (that was the
> reason to have the "hash" of the sql code, to not run the check when
> cross compiling), but I do not find any example in the github actions.
> Thanks.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
