[PROJ] PROJ 9.7.1RC1 & PROJ-data 1.24RC1
Howard Butler howard at hobu.co
Fri Nov 28 06:15:35 PST 2025
+1 Howard
> On Nov 28, 2025, at 6:54 AM, Thomas Knudsen via PROJ <proj at lists.osgeo.org> wrote:
> +1
> /Thomas
> Den fre. 28. nov. 2025 kl. 13.06 skrev Kristian Evers via PROJ <proj at lists.osgeo.org <mailto:proj at lists.osgeo.org>>:
>> PSC members,
>> I have received no reports of problems with the release candidates. You know the drill, I need some +1's ones to proceed with the final releases on Monday.
>> I'll start with my own: +1.
>> /Kristian
>> On Tuesday, November 25th, 2025 at 11:07, Kristian Evers <kristian at evers.dev <mailto:kristian at evers.dev>> wrote:
>> > Everyone,
>> > It’s once again time for a round of releases of the PROJ and PROJ-data packages. I’ve prepared
>> > release candidates for both, which can be downloaded from
>> > https://download.osgeo.org/proj/proj-9.7.1RC1.tar.gz
>> > https://download.osgeo.org/proj/proj-9.7.1RC1.zip
>> > https://download.osgeo.org/proj/proj-data-1.24RC1.tar.gz
>> > https://download.osgeo.org/proj/proj-data-1.24RC1.zip
>> > The PROJ-data release adds a grids for the
>> > * Czech S-JTSK / Krovak East North to S-JTSK/05 / Modified Krovak East North transformation
>> > * Norwegian vertical transformation from NN54 to NN2000 height
>> > * French RGM23 to IGN 2023 Mayotte height transformation
>> > Details for the PROJ release can be found below.
>> > Please report any issues you may find with the release candidates, either here
>> > on the mailing list or in issues on GitHub.
>> > /Kristian
>> > # PROJ Release Notes
>> > ## 9.7.1
>> > ### Updates
>> > * Enable transformations_czechia.sql (#4578)
>> > * Update to EPSG v12.029 (#4586)
>> > ### Bug Fixes
>> > * `createOperations()`: fix compound to compound when vertical CRS definition is equivalent but not strictly identical (#4579)
>> > * `createOperations()`: fix compound to compound when horizontal CRS of … (#4582)
>> > * `projinfo`: make it honour `-k crs` (#4592)
>> > * `proj_clone()`: fix insufficient propagation of `FORCE_OVER=YES` (#4595)
>> > * `BoundCRS::identify`: fix creation of an invalid BoundCRS (that can cause later crashes) for CRS based on 'NTF (Paris)' (#4601)
>> > * WKT/PROJJSON datum ensemble import: allow no members (#4615)
>> PROJ mailing list
>> PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20251128/f4ce151d/attachment.htm>
More information about the PROJ mailing list
