[PROJ] PROJ 9.7.1RC1 & PROJ-data 1.24RC1
Charles Karney
charles.karney at gmail.com
Fri Nov 28 09:02:57 PST 2025
+1
--Charles
On Fri, Nov 28, 2025 at 7:06 AM Kristian Evers via PROJ
<proj at lists.osgeo.org> wrote:
> PSC members,
> I have received no reports of problems with the release candidates. You know the drill, I need some +1's ones to proceed with the final releases on Monday.
> I'll start with my own: +1.
> /Kristian
> On Tuesday, November 25th, 2025 at 11:07, Kristian Evers <kristian at evers.dev> wrote:
> > Everyone,
> > It’s once again time for a round of releases of the PROJ and PROJ-data packages. I’ve prepared
> > release candidates for both, which can be downloaded from
> > https://download.osgeo.org/proj/proj-9.7.1RC1.tar.gz
> > https://download.osgeo.org/proj/proj-9.7.1RC1.zip
> > https://download.osgeo.org/proj/proj-data-1.24RC1.tar.gz
> > https://download.osgeo.org/proj/proj-data-1.24RC1.zip
> > The PROJ-data release adds a grids for the
> > * Czech S-JTSK / Krovak East North to S-JTSK/05 / Modified Krovak East North transformation
> > * Norwegian vertical transformation from NN54 to NN2000 height
> > * French RGM23 to IGN 2023 Mayotte height transformation
> > Details for the PROJ release can be found below.
> > Please report any issues you may find with the release candidates, either here
> > on the mailing list or in issues on GitHub.
> > /Kristian
> > # PROJ Release Notes
> > ## 9.7.1
> > ### Updates
> > * Enable transformations_czechia.sql (#4578)
> > * Update to EPSG v12.029 (#4586)
> > ### Bug Fixes
> > * `createOperations()`: fix compound to compound when vertical CRS definition is equivalent but not strictly identical (#4579)
> > * `createOperations()`: fix compound to compound when horizontal CRS of … (#4582)
> > * `projinfo`: make it honour `-k crs` (#4592)
> > * `proj_clone()`: fix insufficient propagation of `FORCE_OVER=YES` (#4595)
> > * `BoundCRS::identify`: fix creation of an invalid BoundCRS (that can cause later crashes) for CRS based on 'NTF (Paris)' (#4601)
> > * WKT/PROJJSON datum ensemble import: allow no members (#4615)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Charles Karney <karney at alum.mit.edu>
702 Prospect Ave
Princeton, NJ 08540
More information about the PROJ
