[PROJ] Question about new grid file in Czech Rep.
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Oct 6 12:29:56 PDT 2025
Hi
Playing with the latest master in the Czech Republic, I noticed something
strange.
The new grid file cz_cuzk_table_-y-x_3_v1710.tif is used only if the
projected CRS EPSG:5514 is used, but not with its geographic
"parent", S-JTSK EPSG:4156. Well, it is at position 13 on the list of
operations.
Just compare
PROJ_NETWORK=ON ./projinfo -o proj --3d EPSG:4258 EPSG:5514+8357
--spatial-test intersects
with
PROJ_NETWORK=ON ./projinfo -o proj --3d EPSG:4258 EPSG:4156+8357
Doing only 2D transformation, it is even more clear. The grid file is never
used with EPSG:4156
Does it make sense?
I know that the grid file is defined in EPSG:5514. But I assume that the
correction applies to the geographic system transformation, not to the
Krovak projection itself.
Cheers
Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20251006/c4c5935a/attachment.htm>
More information about the PROJ
