[PROJ] Question about new grid file in Czech Rep.
Even Rouault even.rouault at spatialys.com
Mon Oct 6 12:55:07 PDT 2025
Javier,
PROJ is not smart enough to use datum transformations involving a
projected CRS when doing datum transformations between geographic CRS,
without an explicit record in the database. So here you would need to
add a concatenated transformation record chaining
PROJ:ETRS89_3D_TO_S_JTSK_E_N_BALTIC_HEIGHT with the inverse map
projection of S-JTSK / Krovak East North EPSG:5514
Looking at the cuzk online transformer at
https://geoportal.cuzk.cz/(S(aipi30p34gvo5u3w1xywxga3))/Default.aspx?lng=EN&mode=TextMeta&text=wcts&menu=19
, coordinates in S-JTSK can only be given/returned with the projected
CRS. Perhaps it is not "idiomatic" to use geographic coordinates in that
system.
Even
Le 06/10/2025 à 21:29, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> Playing with the latest master in the Czech Republic, I noticed
> something strange.
> The new grid file cz_cuzk_table_-y-x_3_v1710.tif is used only if the
> projected CRS EPSG:5514 is used, but not with its geographic
> "parent", S-JTSK EPSG:4156. Well, it is at position 13 on the list of
> operations.
> Just compare
> PROJ_NETWORK=ON ./projinfo -o proj --3d EPSG:4258 EPSG:5514+8357
> --spatial-test intersects
> with
> PROJ_NETWORK=ON ./projinfo -o proj --3d EPSG:4258 EPSG:4156+8357
> Doing only 2D transformation, it is even more clear. The grid file is
> never used with EPSG:4156
> Does it make sense?
> I know that the grid file is defined in EPSG:5514. But I assume that
> the correction applies to the geographic system transformation, not to
> the Krovak projection itself.
> Cheers
> Javier.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20251006/6c74aa85/attachment.htm>
More information about the PROJ mailing list
