[PROJ] 9.7.0 asks for a warning that is unknown on gcc 7
Greg Troxel gdt at lexort.com
Tue Sep 23 15:37:04 PDT 2025
I got a message that pkgsrc CI showed that proj 9.7.0 failed on NetBSD 9
i386.  I was expecting an i386 issue (vs x86_64), but it was a warning
that is not known by gcc7.
  g++: error: unrecognized command line option '-Wdeprecated-copy-dtor'; did you mean '-Wduplicated-cond'?
  https://releng.netbsd.org/pkgreports/shadow/HEAD/NetBSD-9.0-i386/20250922.1125/proj-9.7.0/build.log
I can't figure out which version of gcc has this.  But proj builds on
NetBSD 10, which has gcc 10.
This patch works around it in pkgsrc, obviously not suitable for proj itself.
--- CMakeLists.txt.orig	2025-09-23 22:12:59.828352847 +0000
+++ CMakeLists.txt
@@ -72,7 +72,6 @@ if("${CMAKE_C_COMPILER_ID}" STREQUAL "GN
     # -Wold-style-cast
     -Woverloaded-virtual
     -Wzero-as-null-pointer-constant
-    -Wdeprecated-copy-dtor
 elseif("${CMAKE_C_COMPILER_ID}" MATCHES "Clang")
   set(PROJ_common_WARN_FLAGS ${PROJ_common_WARN_FLAGS}
With that, tests passed except for "builtins" which says
Reading file '/tmp/work/geography/proj/work/proj-9.7.0/test/gie/builtins.gie'
     FAILURE in builtins.gie(5005):
     expected: 9742698.935838246718 4443057.188599349000
     got:      9742704.587892338634   4443057.289049109444
     deviation:  5652.946631 mm,  expected:  1.000000 mm
     FAILURE in builtins.gie(5021):
     expected: 10363494.047136424109 -4443057.188599349000
     got:      10363499.699190337211   -4443057.088148688897
     deviation:  5652.946468 mm,  expected:  1.000000 mm
and I realize that's not super helpful and I'll see about other
gcc/cpu/etc.
Yes, I just barely realize I should update to 9.7.1, which came out
during our quarterly freeze.
More information about the PROJ mailing list
