[PROJ] Problems in CI: MacOS build
Greg Troxel
gdt at lexort.com
Sat Aug 15 12:07:39 PDT 2026
Greg Troxel via PROJ <proj at lists.osgeo.org> writes:
> I have kicked off a build of proj master on NetBSD 10 aarch64, using gcc
> 10. I'll follow up with how that went; it's going to take a while
> because the machine is slow.
No warnings or errors in the build. All tests pass.
I should be able to test on
macOS x86_64 15
macOS aarch64 16
and will report anything interesting.
More information about the PROJ
