[PROJ] Problems in CI: MacOS build
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Aug 15 14:05:27 PDT 2026
fixed in https://github.com/OSGeo/PROJ/pull/4816
On Sat, 15 Aug 2026 at 21:07, Greg Troxel via PROJ <proj at lists.osgeo.org>
wrote:
> Greg Troxel via PROJ <proj at lists.osgeo.org> writes:
> > I have kicked off a build of proj master on NetBSD 10 aarch64, using gcc
> > 10.  I'll follow up with how that went; it's going to take a while
> > because the machine is slow.
> No warnings or errors in the build.  All tests pass.
> I should be able to test on
>   macOS x86_64 15
>   macOS aarch64 16
> and will report anything interesting.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260815/f865970e/attachment.htm>
More information about the PROJ mailing list
