[PROJ] Unitconvert after topocentric conversion
Even Rouault
even.rouault at spatialys.com
Mon Feb 9 09:54:10 PST 2026
just a syntax issue : replace +pipeline with +proj=pipeline
Even
Le 09/02/2026 à 14:06, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> I would like to compute the difference in a topocentric system (ENU)
> from points in geocentric coordinates... with the output in millimetres.
> echo 4000000.0000 300000.0000 5000001.0000 | cct +pipeline +step
> +proj=topocentric +X_0=4000000.0000 +Y_0=300000.0000 +Z_0=5000000.0000
> +step +proj=unitconvert +xy_in=m +xy_out=mm +z_in=m +z_out=mm
> 0.0000 0.6232 0.7820 inf
> But that is exactly the same output if I do not do the unit conversion.
> Am I doing something wrong?
> Thanks.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260209/5f3862c4/attachment.htm>
More information about the PROJ
