[PROJ] Unitconvert after topocentric conversion
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Feb 9 10:00:53 PST 2026
Thanks Even!
So the syntax was clearly wrong. Should it fail, instead of run just the
first step?
On Mon, 9 Feb 2026 at 18:54, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> just a syntax issue : replace +pipeline with +proj=pipeline
> Even
> Le 09/02/2026 à 14:06, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> I would like to compute the difference in a topocentric system (ENU) from
> points in geocentric coordinates... with the output in millimetres.
> echo 4000000.0000 300000.0000  5000001.0000 | cct +pipeline +step
> +proj=topocentric +X_0=4000000.0000 +Y_0=300000.0000 +Z_0=5000000.0000
> +step +proj=unitconvert +xy_in=m +xy_out=mm +z_in=m +z_out=mm
>         0.0000         0.6232        0.7820           inf
> But that is exactly the same output if I do not do the unit conversion.
> Am I doing something wrong?
> Thanks.
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260209/2213c787/attachment.htm>
More information about the PROJ mailing list
