[PROJ] Wrong transformation in NL?
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sat Feb 21 10:31:15 PST 2026
Hi
Just testing something else, I tried this transformation to go test that
the grids are properly used.
In master this seems to be wrong
echo 52 5 0 | PROJ_DATA=data/ PROJ_NETWORK=ON ./bin/cs2cs EPSG:4326+3855
EPSG:7415
128410.09 445806.51 -43.41
./bin/cs2cs
Rel. 9.8.0, March 2nd, 2026
While in the native cs2cs in Ubuntu 24.04 makes more sense. Just 20 cm
difference between EGM2008 and NAP height.
echo 52 5 0 | PROJ_NETWORK=ON cs2cs EPSG:4326+3855 EPSG:7415
128410.10 445806.50 0.20
cs2cs
Rel. 9.4.0, March 1st, 2024
The first pipeline of the projinfo are ... the same? I don't understand
PROJ_NETWORK=ON projinfo -s EPSG:4326+3855 -t EPSG:7415 -o proj --bbox
5,52,5.1,52.1
Candidate operations found: 2
Operation No. 1:
unknown id, Inverse of WGS 84 to EGM2008 height (1) + Inverse of ETRS89 to
WGS 84 (1) + ETRS89 to NAP height (2) + Inverse of Amersfoort to ETRS89 (9)
+ RD New, 2.002 m, Netherlands - onshore, including Waddenzee, Dutch Wadden
Islands and 12-mile offshore coastal zone.
PROJ string:
+proj=pipeline
+step +proj=axisswap +order=2,1
+step +proj=unitconvert +xy_in=deg +xy_out=rad
+step +proj=vgridshift +grids=us_nga_egm08_25.tif +multiplier=1
+step +inv +proj=vgridshift +grids=nl_nsgi_nlgeo2018.tif +multiplier=1
+step +inv +proj=hgridshift +grids=nl_nsgi_rdtrans2018.tif
+step +proj=sterea +lat_0=52.1561605555556 +lon_0=5.38763888888889
+k=0.9999079
+x_0=155000 +y_0=463000 +ellps=bessel
Operation No. 2:
PROJ_DATA=data/ PROJ_NETWORK=ON ./bin/projinfo -s EPSG:4326+3855 -t
EPSG:7415 -o proj --bbox 5,52,5.1,52.1
Candidate operations found: 6
Operation No. 1:
unknown id, Inverse of WGS 84 to EGM2008 height (1) + Inverse of ETRS89-NLD
[AGRS2010] to WGS 84 (1) + ETRS89-NLD [AGRS2010] to NAP height (2) +
Inverse of Amersfoort to ETRS89-NLD [AGRS2010] (9) + RD New, 1.123 m,
Netherlands - onshore and offshore.
PROJ string:
+proj=pipeline
+k=0.9999079
Operation No. 2:
If my tests are correct, and I had to guess, I would say it is a
consequence of the new ETRS89 ensemble.
Cheers,
Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260221/3d91fd0e/attachment.htm>
More information about the PROJ
