[PROJ] Some (probably dumb) questions about cs2cs and projinfo
Even Rouault
even.rouault at spatialys.com
Tue Feb 24 05:11:47 PST 2026
Le 24/02/2026 à 14:00, Andrea Giudiceandrea via PROJ a écrit :
> Il 24/02/2026 13:23, Andrea Giudiceandrea ha scritto:
>> Thank you very much, Even. Your explanation clarifies all my doubts!
> Actually, not exactly all...
> I wonder why In QGIS the listed transformations available for
> EPSG:23033 -> EPSG:3065 are only 2 (1 grid, 1 ballpark, corresponding
> to projinfo without "--grid-check discard_missing") instead of the 6
> (5 Helmert, 1 ballpark) listed by projinfo with "--grid-check
> discard_missing" or a union of both (1 grid shift, 5 Helmert and 1
> ballpark).
> This creates a discrepancy, making QGIS use a ballpark transformation
> whereas a better one could be used.
> Maybe it would be useful if QGIS could list and let the user choose
> among all the available transformations, wouldn't it?
This is a case where one could argue which one is the best between the
ballpark ED50 -> IGM95 or going through WGS 84 by using a likely poorly
conditionned Helmert transformation. Both results are right and wrong to
some accuracy requirements...
Why IGM is still not releasing freely their grids ? (I remember doing
them some education in Firenze in 2022 ...)
Even
http://www.spatialys.com
More information about the PROJ
