[PROJ] Some (probably dumb) questions about cs2cs and projinfo
Andrea Giudiceandrea andreaerdna at libero.it
Tue Feb 24 06:32:08 PST 2026
Il 24/02/2026 14:11, Even Rouault ha scritto:
> Why IGM is still not releasing freely their grids ? (I remember doing
> them some education in Firenze in 2022 ...)
 > This is a case where one could argue which one is the best between the
 > ballpark ED50 -> IGM95 or going through WGS 84 by using a likely poorly
 > conditionned Helmert transformation. Both results are right and wrong to
 > some accuracy requirements...
You are perfectly right. I'm well aware of the issue. IGM sells the
grids, and, until now, it has not wanted to give up such income making
them freely available...
Some unofficial grid shift files for Italy are however publicity
available, which have the same precision of the official ones, but their
licence and legality is not clear.
Anyway, my concerns and doubts were firstly related to just
understanding the reason why (although they all use the same PROJ and
proj.db), cs2cs (and PostGIS and SpatiaLite) uses a particular (better)
transformation, whereas QGIS another (worst) one, regardless of the fact
that any of such transformations could be considered the right one.
For that transformation, however, all the 5 available Helmert
operations, the first one of which is used by cs2cs (and PostGIS and
SpatiaLite), are much better than the ballpark operation used by QGIS
(which can only choose between the grid shift operation and the ballpark
one), since the ballpark is more than 100 metres off.
Regards.
Andrea
More information about the PROJ mailing list
