[PROJ] Time dependency in ETRFxx to ETRFyy coordinate transformations?
Greg Troxel
gdt at lexort.com
Sun Jun 21 15:14:39 PDT 2026
Even Rouault via PROJ <proj at lists.osgeo.org> writes:
> Xavier, (re-adding the list)
> Thanks for the hint. I should have looked more closely at the WKT
> definition which does indicate the dynamic nature with frameepoch 1989
> (and NATRF2022e2020 is a different beast with an *anchor epoch* of 2020)
indeed but at least by using anchor epoch, the semantics are clear.
I have been wondering about EPSG:6319 (6317), which seems to be a
dynamic frame with a frame reference epoch of 2010.0, but the frame
reference epoch is not part of the EPSG definition. I don't see how the
datum is tagged as static vs dynamic, or is "no frame reference epoch"
--> static?
Do people think this is correct, or not quite?
https://epsg.org/crs_6317/NAD83-2011-.html
More information about the PROJ
