[PROJ] PROJ 9.8.0
Even Rouault
even.rouault at spatialys.com
Mon Mar 2 09:45:15 PST 2026
No, we don't. @Ogi I believe the changes of
https://github.com/OSGeo/PROJ/commit/d65d4203b316ba244b14471728fe629132b67591
have broken the creation of tagged images of PROJ by always creating a
manifest from -latest amd64 and arm64 images. And looking at
https://github.com/OSGeo/PROJ/actions/runs/22577038258/job/65398859539 ,
it also seems that the amd64 and arm64 images for tags don't have the
tag name in their name. We should have logic specific for tags
I just have Internet through mobile phone this week, so can't manually
create & push an image at hand for now.
Le 02/03/2026 à 17:23, Javier Jimenez Shaw via PROJ a écrit :
> Do we have docker image?
> I need it to update spatialreference.org <http://spatialreference.org>
> On Mon, 2 Mar 2026 at 14:17, Kristian Evers via PROJ
> <proj at lists.osgeo.org> wrote:
> It’s my pleasure to announce the release of PROJ 9.8.0!
> The release includes a number of updates, as well as bug fixes.
> See the release notes below.
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.8.0.tar.gz
> https://download.osgeo.org/proj/proj-9.8.0.zip
> /Kristian
> # PROJ Release Notes
> ## 9.8.0
> ### Updates
> * Database: update to EPSG v12.049 (#4671)
> * Database: update ESRI records to ArcGIS Pro 3.6 (#4622)
> * Support for Canadian vertical references MTM CGVD2013 epoch
> 1997, 2002, 2010 and
> UTM CGVD28 epoch 1997, 2002, 2010 (#4623)
> * `createOperationsCompoundToGeog()`: improvement to make "PNG94 /
> PNGMG94 zone 54 + Kumul
> 34 height" to "WGS 84 (G2139)" perform vertical transformation
> (#4624)
> * Remove hardcoding of 'ETRS89-NOR [EUREF89]' cases and generalize
> it to other ETRS89-XXX
> cases (#4625)
> * Database: create ESRI aliases for geodetic_datum and
> geodetic_crs even if they are the
> same as EPSG ones (#4626)
> * Use Emscripten fetch in networkfilemanager (#4627)
> * `ProjectedCRS::identify()`: do not return CRS whose ellipsoid is
> totally different from the input one (#4635)
> * `projinfo` added as a library function. This installs a new
> header: `projapps_lib.h`. (#4646)
> * respect `CRS_EXTENT_USE=NONE` for ConcatenatedOperations (#4652)
> * Add support for Equidistant Cylindrical ellipsoidal method
> (EPSG:1028) (#4656)
> * Update `proj_symbol_rename.h` (#4657)
> * WKT1 importer: deal with 'VERT_CS["Geoid 2012A",' (#4659)
> * Generate correct library name in `proj.pc` (#4660)
> * Derived projected CRS related improvements (#4667)
> * ETRS89-xxx to ETRS89-yyy related improvements (#4668)
> * `createCoordinateOperation()`: tune computed accuracy of a
> concatenated op within ETRS89 (#4670)
> * `createOperationsCompoundToGeog()`: discard 2D-only
> transformations from interpolation
> 3D CRS to target 3D CRS (#4677)
> ### Bug Fixes
> * CRS identification: fix issue when identifying WKT from older
> EPSG releases with newer
> ones where the ETRS89-XXX national datums have been added (#4600)
> * fix `normalizeForVisualization` to skip extent checks for
> axis-swap operations (#4632)
> * Improvements to TRACE_FETCH debug messages (#4645)
> * tmerc spherical: fix numeric instability at lat=lat_0 (#4674)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260302/46f05719/attachment-0001.htm>
More information about the PROJ
