[PROJ] PROJ 9.8.0
Even Rouault
even.rouault at spatialys.com
Sun Mar 8 11:33:26 PDT 2026
I've now fixed the issues in docker.yml, created a 9.8.0-1 tag with only
that extra fix
(https://github.com/OSGeo/PROJ/commit/23fc548f3751d47a675a59bd1ebf29431bbc7f81)
on top of the 9.8.0 tag, and the Docker images are now available as
ghcr.io/osgeo/proj:9.8.0 or docker.io/osgeo/proj:9.8.0
Even
Le 02/03/2026 à 18:45, Even Rouault via PROJ a écrit :
> No, we don't. @Ogi I believe the changes of
> https://github.com/OSGeo/PROJ/commit/d65d4203b316ba244b14471728fe629132b67591
> have broken the creation of tagged images of PROJ by always creating a
> manifest from -latest amd64 and arm64 images. And looking at
> https://github.com/OSGeo/PROJ/actions/runs/22577038258/job/65398859539
> , it also seems that the amd64 and arm64 images for tags don't have
> the tag name in their name. We should have logic specific for tags
> I just have Internet through mobile phone this week, so can't manually
> create & push an image at hand for now.
> Le 02/03/2026 à 17:23, Javier Jimenez Shaw via PROJ a écrit :
>> Do we have docker image?
>> I need it to update spatialreference.org <http://spatialreference.org>
>> On Mon, 2 Mar 2026 at 14:17, Kristian Evers via PROJ
>> <proj at lists.osgeo.org> wrote:
>> It’s my pleasure to announce the release of PROJ 9.8.0!
>> The release includes a number of updates, as well as bug fixes.
>> See the release notes below.
>> Download the archives here:
>> https://download.osgeo.org/proj/proj-9.8.0.tar.gz
>> https://download.osgeo.org/proj/proj-9.8.0.zip
>> /Kristian
>> # PROJ Release Notes
>> ## 9.8.0
>> ### Updates
>> * Database: update to EPSG v12.049 (#4671)
>> * Database: update ESRI records to ArcGIS Pro 3.6 (#4622)
>> * Support for Canadian vertical references MTM CGVD2013 epoch
>> 1997, 2002, 2010 and
>> UTM CGVD28 epoch 1997, 2002, 2010 (#4623)
>> * `createOperationsCompoundToGeog()`: improvement to make "PNG94
>> / PNGMG94 zone 54 + Kumul
>> 34 height" to "WGS 84 (G2139)" perform vertical transformation
>> (#4624)
>> * Remove hardcoding of 'ETRS89-NOR [EUREF89]' cases and
>> generalize it to other ETRS89-XXX
>> cases (#4625)
>> * Database: create ESRI aliases for geodetic_datum and
>> geodetic_crs even if they are the
>> same as EPSG ones (#4626)
>> * Use Emscripten fetch in networkfilemanager (#4627)
>> * `ProjectedCRS::identify()`: do not return CRS whose ellipsoid
>> is totally different from the input one (#4635)
>> * `projinfo` added as a library function. This installs a new
>> header: `projapps_lib.h`. (#4646)
>> * respect `CRS_EXTENT_USE=NONE` for ConcatenatedOperations (#4652)
>> * Add support for Equidistant Cylindrical ellipsoidal method
>> (EPSG:1028) (#4656)
>> * Update `proj_symbol_rename.h` (#4657)
>> * WKT1 importer: deal with 'VERT_CS["Geoid 2012A",' (#4659)
>> * Generate correct library name in `proj.pc` (#4660)
>> * Derived projected CRS related improvements (#4667)
>> * ETRS89-xxx to ETRS89-yyy related improvements (#4668)
>> * `createCoordinateOperation()`: tune computed accuracy of a
>> concatenated op within ETRS89 (#4670)
>> * `createOperationsCompoundToGeog()`: discard 2D-only
>> transformations from interpolation
>> 3D CRS to target 3D CRS (#4677)
>> ### Bug Fixes
>> * CRS identification: fix issue when identifying WKT from older
>> EPSG releases with newer
>> ones where the ETRS89-XXX national datums have been added (#4600)
>> * fix `normalizeForVisualization` to skip extent checks for
>> axis-swap operations (#4632)
>> * Improvements to TRACE_FETCH debug messages (#4645)
>> * tmerc spherical: fix numeric instability at lat=lat_0 (#4674)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
>> PROJ mailing list
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260308/7d9e4d51/attachment.htm>
More information about the PROJ
