[PROJ] Different behaviour between 9.7.1 and 9.8.0
Even Rouault even.rouault at spatialys.com
Wed Mar 11 14:04:29 PDT 2026
Javier,
I suspect this is due to commit 3717ff00afa6872a2ae581de929ba5559ff84438
where I tweaked transformations_czechia.sql, presumably to make existing
tests pass following to the addition of "ETRS89-CZE [2007]". Only a git
bisect session would confirm
Even
Le 10/03/2026 à 16:43, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> This change in behaviour is a surprise to me. I would like to know
> what changed (I know the ETRS89 datum ensemble, but I was not
> expecting this consequence)
> Note: I do not want to change it, just to understand it.
> Context: Going from EPSG:4258 (--3d) to EPSG:5514+8357 is using
> both cz_cuzk_CR-2005.tif and cz_cuzk_table_-y-x_3_v1710.tif in 9.7.1
> and 9.8.0
> The difference is going from EPSG:4326 (--3d) to EPSG:5514+8357. In
> 9.7.1 it is not using cz_cuzk_table_-y-x_3_v1710.tif, but in 9.8.0 it
> does. (both use cz_cuzk_CR-2005.tif)
> What changed? PROJ, EPSG, both?
> Thank you.
> Javier
> PROJ 9.8.0:
> PROJ_NETWORK=ON ./proj_9.8.0/bin/projinfo EPSG:4326 EPSG:5514+8357
> --3d --spatial-test intersects --bbox 15,50,15.1,50.1 -o proj | head -n 40
> Candidate operations found: 12
> Operation No. 1:
> unknown id, Inverse of ETRS89-CZE [2007] to WGS 84 (1) + ETRS89-CZE
> [2007] to Baltic 1957 height (2) + Inverse of S-JTSK/05 to ETRS89-CZE
> [2007] (1) + Modified Krovak East North (Greenwich) + Inverse of
> S-JTSK / Krovak East North (EPSG:5514) to S-JTSK/05 / Modified Krovak
> East North (EPSG:5516) + Inverse of Krovak East North (Greenwich) +
> Krovak East North (Greenwich), 1.065 m, Czechia.
> ... pipeline omitted. It uses cz_cuzk_CR-2005.tif
> PROJ 9.7.1:
> PROJ_NETWORK=ON ./proj_9.7.1/bin/projinfo EPSG:4326 EPSG:5514+8357
> Candidate operations found: 7
> Operation No. 1:
> unknown id, Inverse of ETRS89 to WGS 84 (1) + ETRS89 to Baltic 1957
> height (2) + Inverse of S-JTSK to ETRS89 (1) + Krovak East North
> (Greenwich), 2.03 m, Czechia.
> ... pipeline omitted. It only uses cz_cuzk_CR-2005.tif
> As a reference, from EPSG:4258 it doing this
> PROJ_NETWORK=ON ./proj_9.8.0/bin/projinfo EPSG:4258 EPSG:5514+8357
> Candidate operations found: 10
> Operation No. 1:
> PROJ:ETRS89_3D_TO_S_JTSK_E_N_BALTIC_HEIGHT, ETRS89 to S-JTSK / Krovak
> East North + Baltic 1957 height, 0.05 m, Czechia.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260311/2b4c3a33/attachment-0001.htm>
More information about the PROJ mailing list
