[PROJ] Different behaviour between 9.7.1 and 9.8.0
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed Mar 11 14:14:40 PDT 2026
Thank you Even.
I was not aware of those changes... it is easy to miss something on the
EPSG updates. The same way I missed the new German CRS from 2025.
On Wed, 11 Mar 2026 at 22:04, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> I suspect this is due to commit 3717ff00afa6872a2ae581de929ba5559ff84438
> where I tweaked transformations_czechia.sql, presumably to make existing
> tests pass following to the addition of "ETRS89-CZE [2007]". Only a git
> bisect session would confirm
> Even
> Le 10/03/2026 à 16:43, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> This change in behaviour is a surprise to me. I would like to know what
> changed (I know the ETRS89 datum ensemble, but I was not expecting this
> consequence)
> Note: I do not want to change it, just to understand it.
> Context: Going from EPSG:4258 (--3d) to EPSG:5514+8357 is using
> both cz_cuzk_CR-2005.tif and cz_cuzk_table_-y-x_3_v1710.tif in 9.7.1 and
> 9.8.0
> The difference is going from EPSG:4326 (--3d) to EPSG:5514+8357. In 9.7.1
> it is not using cz_cuzk_table_-y-x_3_v1710.tif, but in 9.8.0 it does. (both
> use cz_cuzk_CR-2005.tif)
> What changed? PROJ, EPSG, both?
> Thank you.
> Javier
> PROJ 9.8.0:
> PROJ_NETWORK=ON ./proj_9.8.0/bin/projinfo EPSG:4326 EPSG:5514+8357 --3d
> --spatial-test intersects --bbox 15,50,15.1,50.1 -o proj | head -n 40
> Candidate operations found: 12
> Operation No. 1:
> unknown id, Inverse of ETRS89-CZE [2007] to WGS 84 (1) + ETRS89-CZE [2007]
> to Baltic 1957 height (2) + Inverse of S-JTSK/05 to ETRS89-CZE [2007] (1) +
> Modified Krovak East North (Greenwich) + Inverse of S-JTSK / Krovak East
> North (EPSG:5514) to S-JTSK/05 / Modified Krovak East North (EPSG:5516) +
> Inverse of Krovak East North (Greenwich) + Krovak East North (Greenwich),
> 1.065 m, Czechia.
> ... pipeline omitted. It uses cz_cuzk_CR-2005.tif
> PROJ 9.7.1:
> PROJ_NETWORK=ON ./proj_9.7.1/bin/projinfo EPSG:4326 EPSG:5514+8357 --3d
> Candidate operations found: 7
> Operation No. 1:
> unknown id, Inverse of ETRS89 to WGS 84 (1) + ETRS89 to Baltic 1957 height
> (2) + Inverse of S-JTSK to ETRS89 (1) + Krovak East North (Greenwich), 2.03
> m, Czechia.
> ... pipeline omitted. It only uses cz_cuzk_CR-2005.tif
> As a reference, from EPSG:4258 it doing this
> PROJ_NETWORK=ON ./proj_9.8.0/bin/projinfo EPSG:4258 EPSG:5514+8357 --3d
> Candidate operations found: 10
> Operation No. 1:
> PROJ:ETRS89_3D_TO_S_JTSK_E_N_BALTIC_HEIGHT, ETRS89 to S-JTSK / Krovak
> East North + Baltic 1957 height, 0.05 m, Czechia.
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260311/6e8b6319/attachment.htm>
More information about the PROJ
