[PROJ] cdn.proj.org stats?
Jürgen E. Fischer
jef at norbit.de
Mon Mar 23 01:57:58 PDT 2026
QGIS currently ships full proj-data with the windows msi installers and that's
a good part of the installer. We're trying to reduce that and therefore I'm
now looking (again) into which grids could be separated.
I suppose
"Access logs to this resource are permanently deleted after one day, are not
mirrored or stored, and are not publicly available. If this policy is not
sufficient, users are encourage to mirror a local copy of the grid files and
access them directly."
means that there is no stats that could help with this - ie. identifying huge
grids that are never used (eg. maybe de_lgl_bw_BWTA2017.tif)
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany Matrix: @jef:osgeo.org
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260323/c909e96e/attachment.sig>
More information about the PROJ
