[PROJ] cdn.proj.org stats?
Michael Smith michael.smith.erdc at gmail.com
Mon Mar 23 02:56:49 PDT 2026
Could you distribute 2 bundles?
1. Full proj grid data
2. No proj grid data and PROJ_NETWORK=on to fetch over http
Then you'd have an offline/online versions of QGIS.
Another option would be just an QGIS installer around the PROJ grid bundles that would install for qgis.
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
On 3/23/26, 4:58 AM, "PROJ on behalf of Jürgen E. Fischer via PROJ" <proj-bounces at lists.osgeo.org <mailto:proj-bounces at lists.osgeo.org> on behalf of proj at lists.osgeo.org <mailto:proj at lists.osgeo.org>> wrote:
QGIS currently ships full proj-data with the windows msi installers and that's
a good part of the installer. We're trying to reduce that and therefore I'm
now looking (again) into which grids could be separated.
I suppose
"Access logs to this resource are permanently deleted after one day, are not
mirrored or stored, and are not publicly available. If this policy is not
sufficient, users are encourage to mirror a local copy of the grid files and
access them directly."
means that there is no stats that could help with this - ie. identifying huge
grids that are never used (eg. maybe de_lgl_bw_BWTA2017.tif)
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de <https://www.norbit.de>
QGIS release manager (PSC) Germany Matrix: @jef:osgeo.org
PROJ mailing list
PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj <https://lists.osgeo.org/mailman/listinfo/proj>
More information about the PROJ mailing list
