[PROJ] transformations with epoch
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Tue Mar 24 06:09:37 PDT 2026
Hi
Unfortunately, no one reacted to this question. I would be interested in an answer too, because I don’t understand the cs2cs behaviour either. Even worse: I don’t understand how there can be a different epoch for source and target CRS without specifying a velocity vector for the point of interest (like https://www.epncb.oma.be/_productsservices/coord_trans/) or a deformation grid model.
Jochem
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Javier Jimenez Shaw via PROJ
Sent: zaterdag 14 maart 2026 23:53
To: proj <PROJ at lists.osgeo.org>
Subject: [PROJ] transformations with epoch
Hi
I have been playing with epochs today. Maybe I am understanding something wrongly, but the outputs are very strange.
My deductions are:
- the 4th dimension (v_4) from the input is just copied into the output of cs2cs. Independently of epoch flags.
- if --s_epoch or --t_epoch are set, the input v_4 is ignored (but still printed in the output)
- if only --s_epoch or --t_epoch is set, v_4 is set before and after the transformation to that value
- if both are set, v_4 is set to s_epoch before transforming, and to t_epoch after. So in this case t_epoch only works to tag the output time,... but it is not displayed in cs2cs (it is in the C function)
Is that correct? Why is t_epoch overwriting the input time/epoch? Why is s_epoch setting the output time/epoch?
In addition, cs2cs is apparently not printing the modified output epoch. This is not what C function does.
Here are some transformations using the input epoch in the coordinates and the --s_epoch and --t_epoch
echo 40 0 0 | ./cs2cs ITRF90 ITRF2014  -d 9
40.000000788 -0.000000207 0.009684166
echo 40 0 0 foo bar | ./cs2cs ITRF90 ITRF2014  -d 9
40.000000788 -0.000000207 0.009684166 foo bar
echo 40 0 0 2010 | ./cs2cs ITRF90 ITRF2014  -d 9
40.000000788 -0.000000207 0.009684166 2010
echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014  -d 9
40.000000087 -0.000000216 -0.028724159 1980
echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014  -d 9 --s_epoch 2000
40.000000555 -0.000000210 -0.003118609 1980
echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014  -d 9 --s_epoch 2010
40.000000788 -0.000000207 0.009684166 1980
echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014  -d 9 --s_epoch 2010 --t_epoch 2030
echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014  -d 9 --s_epoch 2000 --t_epoch 2030
echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014  -d 9 --t_epoch 2010
echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014  -d 9 --t_epoch 2030
40.000001256 -0.000000201 0.035289716 1980
The pipelines for some cases are
without setting --s_epoch or --t_epoch
+proj=pipeline
  +step +proj=axisswap +order=2,1
  +step +proj=unitconvert +xy_in=deg +z_in=m +xy_out=rad +z_out=m
  +step +proj=cart +ellps=GRS80
  +step +proj=helmert +x=-0.0254 +y=-0.0115 +z=0.0928 +rx=0 +ry=0 +rz=-0.00026
        +s=-0.00479 +dx=-0.0001 +dy=0.0005 +dz=0.0033 +drx=0 +dry=0 +drz=-2e-05
        +ds=-0.00012 +t_epoch=2010 +convention=position_vector
  +step +inv +proj=cart +ellps=GRS80
  +step +proj=unitconvert +xy_in=rad +z_in=m +xy_out=deg +z_out=m
setting --s_epoch to 2000
+proj=pipeline
  +step +proj=set +v_4=2000
setting --t_epoch to 2030
+proj=pipeline
  +step +proj=set +v_4=2030
setting --s_epoch to 2000 and --t_epoch to 2030
+proj=pipeline
PS https://jjimenezshaw.github.io/wasm-proj/transform.html is in this case probably showing better the output of the C function.
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260324/92e7dc7f/attachment-0001.htm>
More information about the PROJ mailing list
